504 wont start after head repalcement-HELP PLEASE!
Randy
06-22-2004 12:53:54
just replaced the head on my 504 gas it was cracked and had 2 bad valves.So found good used head put new guides,all valves, ground seats.torqued to 88lbs new head set new water pump themostat,hoses etc.It had run before the head replacement with the carb I rebuilt and put on it
At first I would get a nasty backfire,still wouldnt run,reset valve clearance-rechecked about 6 times,not even any smoke now,plugs are firing,carb is getting gas-still wont start what am I missing??
ANY HELP WOULD BE APPRECIATED-THANKS IN ADVANCE
RANDY
Jon
06-22-2004 14:26:39
 Re: 504 wont start after head repalcement-HELP PLE in reply to Randy, 06-22-2004 12:53:54
If you did not have the distributor off I would say you have the wires screwed up. sound like the timing or spark plug wires to me. JON
TomH
06-22-2004 16:14:43
 Re: Re: 504 wont start after head repalcement-HELP in reply to Jon, 06-22-2004 14:26:39
Yup. Backfiring is a sign the wires are wrong or it's waaaay out of time.
