farmall A
Don Mallick
06-22-2004 16:09:40
can i put the supper c kit in a supper a block? and do i have to machine work done
gene b
06-22-2004 19:43:12
 Re: farmall A in reply to Don Mallick, 06-22-2004 16:09:40
Depends on which kit you buy. Are you going with hi-dome and where are you going to get the kit? The kits will normally ask which casting # is on the block.
parts man
06-22-2004 19:26:05
Don, there are 2 different sizes to the bottom of the sleeves of a 113 or 123 block. As long as both blocks take the same OD at the bottom of the sleeve you're OK.
