1066 problems
matt
06-22-2004 21:26:10
1466, i have a 1466 and was wondering if it is normal for the 66 series tractors to have grind marks and the hyd fluid dip stick , all i am used to is 86 series and do not have a clue, i also have a problem with it jerking as soon as it becomes under load, it will be driving fine but as soon as it starts pulling hard it will jerk hard like it is taking up the slack in something, i was wondering what this could be , thank you
Aces
06-23-2004 04:56:44
 Re: 1066 problems in reply to matt, 06-22-2004 21:26:10
Matt as for the dip stick it is posable to put it in on a slant enough for the gears to grind on it. If it is put in straight enough that will not happen. As for the jerk I would say it is in the TA, but you did not say if you were in TA or direct.
