GOVERNOR FOR 50 M
BUBSDAD
06-24-2004 16:57:18
ENGINE SPEED DOESN'T RESPOND TO THE CHANGE IN THROTTLE POSITION. IT WILL ONLY IDLE, BUT IT STILL HAS MORE POWER THAN MY JOHN DEERE.
THE LINKAGE IS ALL HOOKED UP AND OPERATES, BEFORE I START PULLING COVERS IS THERE A COMMON PROBLEM TO LOOK FOR??
THANK YOU
Jon
06-24-2004 18:02:04
 Re: GOVERNOR FOR 50 M in reply to BUBSDAD, 06-24-2004 16:57:18
Is your carb adjusted right? Next I would check the linkage that hooks to the carb . Make sure its seated in the right postion in the carb . Lossen the two screws that hold it on the carb and wiggle and turn it and see if that makes a different.I guess next would be to pull the cover off the GOV . Check holes for wear like where spring hooks,Spring ,Govener Adjustments, JON
