Age, value of M
Don
06-24-2004 19:58:22
I have an M that has a second fuel tank in front of the main tank, it only holds maybe a gallon of fuel. Can anyone tell what it is for, whether it is a reserve tank or maybe a different type of fuel? Also if anyone knows serial numbers for years? And last value it is gas, standard drawbar, narrow front? Thank you
little john
06-25-2004 03:38:09
 Re: Age, value of M in reply to Don, 06-24-2004 19:58:22
Go to the left of the forum page under Research & Info and you will see serial number information.
David B
06-24-2004 21:46:46
The small tank is a starter tank for distillate burners. It held the gas the tractors started on, and then turned off when the tractor got hot enough to burn the distillate in the big tank.
Need more information for value; condition of paint, sheetmetal, tires, and engine. Year could also make a difference.
