Gear/clutch plate problem
Phil
06-25-2004 18:01:34
Cranked a '66 140 after about a year sitting from a slow cleanup and paint project. Now, when I press the clutch, the shaft won't stop turning and I can't get it into gear. Could it be that the clutch plate is stuck or what. I don't want to strip the teeth on the gear and it shifted when I drove it last year.
Red Rookie in Wi
06-26-2004 03:51:02
 Re: Gear/clutch plate problem in reply to Phil, 06-25-2004 18:01:34
Phil, The cluth probably rusted to the flywheel and pressure plate. Shouldn't be stuck that bad after only a year. Try pulling it with the tranny in the highest gear that will turn the engine over and keep pressing the clutch. Just make sure the ignition is off so it doesn't start and run into the tow vehicle. Or put it on a jack stand so that one wheel is off the ground. Start the tractor in 4th gear, rev it up ang have someone push it off the jackstand while you hold the clutch pedal down. My 240U had sat for 8 years and I ended up splitting it. Mice built a huge nest in the bellhousing and the combination of urine and humidity rusted it solid. Splitting a small tractor is so easy that you might want to do it right away. Then you can clean up everything nice and smooth and get it operating perfectly. Good luck
Phil
06-26-2004 19:22:37
 Re: Re: Gear/clutch plate problem in reply to Red Rookie in Wi, 06-26-2004 03:51:02
thank you
Matt
06-25-2004 18:50:16
It does sound like the clutch plate is sticking and of course, not allowing you to shift gears.
Phil
06-26-2004 19:22:07
 Re: Re: Gear/clutch plate problem in reply to Matt, 06-25-2004 18:50:16
thank you
