Farmall 230 Carb
IH230
06-26-2004 09:41:21
Farmall 230 started acting up, only wants to run with full choke. I have checked gas flow at the carb and the inlet screen and they appear ok. I drained gas tank and put in new gas and cleaned the sediment bowl & screen. I drained the carb several times.
I have good spark at the plugs. I checked the air cleaner.
Do I need to rebuild the carb? Or, am I missing something else?
Thanks in advance for your help.
Dennis E. Kearney
06-26-2004 20:35:34
 Re: Farmall 230 Carb in reply to IH230, 06-26-2004 09:41:21
wide front? what year ?
IH230
06-27-2004 05:18:39
 Re: Re: Farmall 230 Carb in reply to Dennis E. Kearney, 06-26-2004 20:35:34
1957 with a wide front end.
CNKS
06-26-2004 14:32:40
Clean it in carb cleaner, blow out all passages with compressed air, and put a kit in it.
Matt
06-26-2004 10:20:04
Hi, I'm not sure about what would be causing that, but did you buy that tractor in Carlisle, PA?
IH230
06-26-2004 10:35:13
 Re: Re: Farmall 230 Carb in reply to Matt, 06-26-2004 10:20:04
No. Purchased near Flint Hill, MO (just outside St. Louis, MO)
