SuperAV Tom
06-26-2004 15:28:44
What is the correct paint code for International Red and the silver in the wheels to have paint mixed for a 1949 Super AV? I would like to use OMNI paint.
Thank You
Tom
sammy the RED
06-27-2004 21:23:39
 Re: Paint Codes in reply to SuperAV Tom, 06-26-2004 15:28:44
Most of the guys use a good quality aluminum for the rims.
Wheels are painted red.
Rudi
06-26-2004 17:34:08
third party image
Tom:
If you click on the link below, then Paint, Decals and Other Finish ?'s, then Paint Chart, you will find the proper paint codes for IH Iron Gard and other automotive products.
On2Wheels
06-26-2004 17:05:44
For Omni AU the red it is 2370. I am not sure what the silver for the wheels is, but I painted the front wheels on my M with Well-Worth Prisma Acrylic Enamel Dull Aluminum.
CNKS
06-26-2004 17:46:12
 Re: Re: Paint Codes in reply to On2Wheels, 06-26-2004 17:05:44
Where did you get 2370 -- Only PPG codes I know are 70019 for IH 50 for pre 1949 tractors, 71310 for IH 2150 for post 1949. There is no code for the wheels because they were galvanized, I use PPG 8568-- sort of a grayish-silver color.
On2Wheels
06-26-2004 19:49:07
 Re: Re: Re: Paint Codes in reply to CNKS, 06-26-2004 17:46:12
On the can of my Omni AU (made by PPG) it reads For OEM: 2370. As this is the MTK can it also reads MTK 71969ALT C RED.
CNKS
06-27-2004 14:11:42
 Re: Re: Re: Re: Paint Codes in reply to On2Wheels, 06-26-2004 19:49:07
The correct codes are 50 (PPG 70019) or 2150 (71310), depending on when the tractor was made. There was another code, 1102B, used between 50 and 2150, but I don't think it can be mixed. I don't know if the later models had a different code before IH was acquired by Tenneco. The current Case-IH tractors are a different color. I don't know what 2370 (71969) is, it is not a color for IH tractors we are currently discussing, but if you like it, ok. Curious as to where you found that number. PPG acrylic enamel (MAE) and acrylic urethane (MTK) have the same paint code.
