Super C headlite wiring
Plowpusher
06-26-2004 18:26:17
IS there a trick to get new wiring from the headlites into the insterment box? thank you
Farmer Bob
06-26-2004 20:57:13
 Re: Super C headlite wiring in reply to Plowpusher, 06-26-2004 18:26:17
Take a long piece of 12 or 14 gauge stranded wire and fish it straight through the horizontal light bar. Then take a length of straightened out coat hanger and make a small hook in the end of it. Fish the "Hooked" end up into the vertical pedistal and grab the wire that you pulled through the light bar. Pull the wire down into the pedistal, cut, strip and connect it to the proper terminal of the light switch. Leave enough hanging out of both ends of the light bar to connect to the back of the lights.
PLOWPUSHER
06-27-2004 21:13:28
 Re: Re: Super C headlite wiring in reply to Farmer Bob, 06-26-2004 20:57:13
FARMER BOB, Thanks for the information>>> worked great on the 3rd try >>> plowpusher
Ed H.
06-26-2004 18:45:34
its easier to run the wires from the inst. box to the lights, you will probobly have to unbolt the pedastal on top of the box
