What do I have??
Del
06-27-2004 16:45:25
I just picked up a Farmall C. I think? The serial number on the tool box has 2 numbers on it. The top number is 51345 and if that is the serial number, it is a 50. The bottom number is 1815 which makes it a 48. Also the paint is really rough and it appears that it was painted white at one time. There is white residue on the hood, grill, trans, axle housings etc. Could this be a demonstrator? I would prefer not, because I want to paint it red. Any help is appreciated--thanks in advance. I believe it is a C, has drum brakes and it is hard to tell if "Super" in in the org decal.
CNKS
06-27-2004 17:31:06
 Re: What do I have?? in reply to Del, 06-27-2004 16:45:25
Your serial is in the the "accepted" serial number range of 47010-54411 for white demos. 1815 is the max rpm. You are not required to paint it white. I have a white C I painted red, because I don't like the looks of white Farmalls. Take lots of pictures, in case you want to sell it some day. The fact that it was originally white may make it worth more -- may not too.
Del
06-27-2004 18:50:34
 Re: Re: What do I have?? in reply to CNKS, 06-27-2004 17:31:06
Thanks for the info! I don't like the white color either.
