H MOTOR WEIGHT
JON
06-27-2004 17:13:08
Hi again does anybody know what the weight of a full H motor is with the flywheel. I need to go get myself a motor stand and I was wondering if I can go with the 750LB or if I need to go higher.I may use it for an M in the future to. JON
riverbend
06-27-2004 20:14:41
 Re: H MOTOR WEIGHT in reply to JON, 06-27-2004 17:13:08
On the other hand, I would doubt that the motor and flywheel weigh more than 750 pounds. From wrestling the short block on the work bench this fall, I would say that much weighed a couple hundred pounds. Neither the head or the flywheel weigh 100# a piece. Front cover, governor, manifold, another 100# ? I'm guessing that it would come in around 500#.
What is the price and quality difference between the 750# and the next bigger engine stand ?
TDK
06-27-2004 20:12:33
I believe the H motor will weight between 450 & 475 lbs. Do as Jeff says, get the heavier one,an M motor is roughly 650 lbs.
Jeff In Ontario
06-27-2004 17:49:55
I could be wrong, but i think a full H engine with flywheel is heavier than that so I would play it safe and get a bigger one-especially if you are going to use it on an M at some point. That's just my personal opinion, hope it helps! ---Jeff
