M starting trouble
William Ransom
06-28-2004 14:48:30
Today, we started the M for the first time since I cleaned out the carburetor and installed the fuel filter. It started easily enough, but after starting, it seemed to be about to stall several times, and the choke had to be closed and opened again several times to stop it from stalling. After a while it started running all right, and kept running right until I stopped it, after driving it to our driveway. (This is the first time the M has been parked along our driveway since 1989, if I remember right.) After I stopped the engine, I noticed gas dripping from the carburetor. Why do you think it took so long for it to start running right?
williamf
06-28-2004 18:47:48
 Re: M starting trouble in reply to William Ransom, 06-28-2004 14:48:30
My H often needs a little quick choke work when I first start it up, even in warm weather. Did you try to start it again after it had been running a while?
The rebuilt carb I put on would also drip sometimes when I shut it off. After a few months it quit doing that. I still cut the fuel off before I walk away, but when I'm right there and leave it on it doesn't drip. I still cut it off before I leave.
Wm
Rock
06-28-2004 17:56:42
I have a few of the old farmalls and most will drip a little when you cut the tractor off. I have totally rebuilt carbs and still have a little drip sometimes. I wouldnt want mine steady dripping but a couple of drips at cut off isnt out of the ordinary. If you have a steady drip then you have a problem that needs fixin. Needle isnt seating firmly. Cut the fuel off when not in use regardless.
Rock
