Engine miss on H
Farmall Ed
06-29-2004 05:49:10
Awhile back I was plowing and the engine on my H started missing when under a load. I changed the plugs,points,condensor,and put a new kit in the carburator. It still misses at high rpm loaded or not. I have it pin pointed to the #2 cylinder,but I havent figured out why. Any help would be appreciated. Thanks Ed
Captaink
06-29-2004 09:07:11
 Re: Engine miss on H in reply to Farmall Ed, 06-29-2004 05:49:10
I would suggest taking a compression test first. If the compression is close on all four cylinders, try a different spark plug wire on the #2 cylinder. If it still misses try a different distributor cap.
If the #2 cylinder compression is over 20% lower than the other three you have a compression leak which probably will be related to the exhaust valve. (If you are hearing “popping” in the air cleaner, that indicates it is an intake valve.) Check the valve lash on the #2 cylinder. If that is correct you may have a valve that is starting to "burn" and may only be able to notice it under a hard load.
Hope this helps...
