Super M / 400 head oiler
Bill Evans
06-29-2004 09:48:28
I removed the valve cover on my Super M for a valve adjustment and noticed an oil line running the length of the head and above the rockers. I assume its purpose is to shower oil down onto the rockers. The reason this part got my attention is that I just finished a 400 overhaul and this overhead oiler was NOT present on that tractor, but I do recall the ports being in the head and wondering what they were for. Now I know!
Is this line important? Should I be concerned about the 400?
Thanks.
Aces
06-29-2004 10:28:18
 Re: Super M / 400 head oiler in reply to Bill Evans, 06-29-2004 09:48:28
Bill that is not an oiler it is a breather if you follow it all the way you will see it goes out the back of the head and into the air cleaner. The 400 should have had a short pipe at each end of the head to do the samw thing the tube that sets on top of the governer is part of this.
Bill
06-29-2004 17:45:00
 Re: Re: Super M / 400 head oiler in reply to Aces, 06-29-2004 10:28:18
So, it is a breather. Thanks for setting me straight.
Bob M
06-29-2004 10:25:48
Bill - On the SM that tube is the "cylinder head breather". It ventilates the rocker box via a second, external tube running from the rear of the head to the air cleaner inlet.
Rocker shaft oil supply is provided by a tube and sleeve assembly mounted on the rocker shaft between the two middle cylinders.
I gotta think the 400 breather is the same (it uses the same C264 engine). Perhaps the head breather tube is missing on your 400??
Bill Evans
06-29-2004 17:46:29
 Re: Re: Super M / 400 head oiler in reply to Bob M, 06-29-2004 10:25:48
Yes, this breather device is obviously missing. Anybody have one?
Dave W V
06-29-2004 19:08:06
 Re: Re: Re: Super M / 400 head oiler in reply to Bill Evans, 06-29-2004 17:46:29
Bill if your 400 is factory IH it never used the pipe.As other reply said they used a short pipe
in front hole in head maybe 1 1/2 to 2 inch long.
Also rocker cover used a hole in top piped to air cleaner pipe.M and SM used a hole out back of head to air
cleaner pipe.M-SM cover only had bolt holes in it.
Bill Evans
06-30-2004 04:34:09
 Re: Re: Re: Re: Super M / 400 head oiler in reply to Dave W V, 06-29-2004 19:08:06
Yes, that all makes sense now. Thanks for the info!
