farmall 100 voltage regulator change
walt dillon
06-29-2004 18:22:38
do i need to polorize new voltage regulator after removing old one? how do i go about doing this? thanks, walt
Bob M
06-30-2004 06:28:45
 Re: farmall 100 voltage regulator change in reply to walt dillon, 06-29-2004 18:22:38
Walt - It's actually the generator that requires polarizing.... Anyway repolarizing after making any change to the charging system is always a good idea. It's cheap insurance, and it only takes a second. Here's how:
With everything connected and the ignition switch off, take a scrap of wire and momentarily jumper the BAT and GEN terminals at the regulator . The instant contact is made (you should see a small spark) you have successfully polarized.
