Order Farmall Cub Parts Online
cub lo-boy rear main seal
george
06-29-2004 18:26:59
1964 IH cub lo-boy rear main seal leaking.do i need to remove the engine or can i change the seal in the tractor by removing the oil pan?also,is there a recirulating pump available for the cooling system?
Rudi
06-29-2004 19:20:53
 Re: cub lo-boy rear main seal in reply to george, 06-29-2004 18:26:59
third party image
George:
Mine is leaking also, and I think that the tractor must be split to change it, but hey, I never did it before so I am not the one to ask. However, check the GSS-1411 Service Manual on the server at the link below. It should tell you. I would look it up by my printed manuals are down in the shop.
Answer to your second question is I don't think so. Interesting question though.
