MW live pump
Randy SE-MN
06-30-2004 06:18:17
Does any on kwow any outfit that rebuilds M&W live pumps? I bought one from a sheister in southern Iowa who claimed it was good (I still have his e-mails). It leaks a quart of oil a night into the crankcase of my M. Any help appreciated.
CNKS
06-30-2004 18:28:07
 Re: MW live pump in reply to Randy SE-MN, 06-30-2004 06:18:17
Most likely all you need is the seal at the front of the pump. Pump is easy to remove, seal is easy to replace, if the shaft is worn, you may need a speedy sleeve. $5-10 seal, $20-25 sleeve should do it.
Randy SE-MN
07-01-2004 07:42:56
 Re: Re: MW live pump in reply to CNKS, 06-30-2004 18:28:07
Thanks for the reply. I figured it was just a seal that went bad. I hope the shaft is good,the pump sounds ok. Thanks again
