Lowboy mower
JD
06-30-2004 07:58:04
I have a 60" 3 blade Lowboy mower (ser # 601 U-1111) on a 49 regular Cub and have trashed the main blade drive shaft. I am looking for an online schematic of the unit and a source for repair parts (other than Case) or better yet a source for a complete used unit with dual pulley and 3 bolt mounting bracket. Thanks for any ideas. JD
K-Mo
06-30-2004 15:24:56
 Re: Lowboy mower in reply to JD, 06-30-2004 07:58:04
I'm assuming you ahave a C1, C2 or C3 mower. I have a C1 mounted on a Cub Lo-Boy which mounts to the sides of the clutch housing. It is an International Danuser/Danco C-1. I also have a 3160 (C3) mounted on an IH 184 with the primary mounting to the rear axle housing. If you have a C1 or C3, give me your email and I'll do what I can to help.
It is my guess these mowers (Danuser/Danco) are now supported by Woods.
Good Luck,
K-Mo
JD
07-01-2004 09:31:23
 Re: Re: Lowboy mower in reply to K-Mo, 06-30-2004 15:24:56
Thanks K-Mo, would appreciate that, I have a throw away mail account at bgrg@aol.com. JD
Bigdog
06-30-2004 10:42:09
Check here for a manual:
