Farmall 340 weights
Al L. in Wisc.
06-30-2004 15:31:43
Does anyone make frame weights for a Farmall 340 rowcrop? Mine sure could use them. Thanks.
Chris
07-01-2004 04:00:47
 Re: Farmall 340 weights in reply to Al L. in Wisc., 06-30-2004 15:31:43
call Easy Bobs Tractor Parts 765-675-2530, I know he has a set for sale, they are the slab frame wights not the suitcase type.
Hugh MacKay
06-30-2004 18:11:26
Al: The 340 will take the rack for suitcase weights. It bolts to the 4 holes in your front casting. There were frame weights for 340 when they were new a bolt on type. You will find suitcase type much easier. The rack can be quite easily fabricated. Quick to mount or remove, I think you would like them much better.
