460 engine swap
doorguy
06-30-2004 20:16:21
I have an IH 460 Utility LP that is getting tired. I located a 715 LP Combine that I believe to be a 291" engine. They look the same externally, will it bolt in? I know I will have to change timing cover to attach front bolster. Any help will be appreciated. Thanks, doorguy
Aces
07-01-2004 10:44:28
 Re: 460 engine swap in reply to doorguy, 06-30-2004 20:16:21
doorguy you can do it but you might have to go clear to the block front and back to get the right mountings changed.
