Question on steering problem on a 350.
Jeff in IA
07-01-2004 09:29:20
I was mowing yesterday when the steering mechanism broke. It didn't feel like anything snapped, just that the front wheels suddenly wouldn't turn left or right. The entire steering mechanism turns with the steering wheel including the vertical shaft in front of the radiator. Something is broken between where that vertical shaft goes into the lower chassis and where it comes out. The shaft above the chassis turns, but the lower shaft/axle does not turn left or right.
Do any of you know what I may need to fix? Is there a sheer pin in there that broke or is it more serious than that? Any advice would be appreciated.
RPM
07-01-2004 13:36:59
 Re: Question on steering problem on a 350. in reply to Jeff in IA, 07-01-2004 09:29:20
Ace is right, you broke the vertical steering shaft, same as a H-Super H-300-350, part # 69060D, you can get one from Herschel-Adams 1 800 247 2167, their part 533265 $170 + ups.
Jeff in IA
07-01-2004 15:16:11
 Re: Re: Question on steering problem on a 350. in reply to RPM, 07-01-2004 13:36:59
Wow. That is what I was looking for. Thanks alot!
Aces
07-01-2004 10:41:05
Jeff you broke the vertical or bolster shaft just above the bottom bushing.
Hoppy
07-01-2004 14:06:55
 Re: Re: Question on steering problem on a 350. in reply to Aces, 07-01-2004 10:41:05
After rereading your post I have to agree with Aces, you need a steering pedestle. I missed the fact that your verticle shaft was turning. You may want to put in a new bushing, bearing and thrust washer at the same time.
Jeff in IA
07-01-2004 15:21:17
 Re: Re: Re: Question on steering problem on a 350. in reply to Hoppy, 07-01-2004 14:06:55
Found the answer above. Thanks again for all the help.
Jeff in IA
07-01-2004 15:07:05
Thanks Hoppy. Now, any good advice on where to get a new one? I've got a large tractor salvage yard near here, but it sounds like I may want new parts.
Jeff in IA
07-01-2004 13:08:59
Thanks. Any idea how to fix? Is there a way to pin it, as suggested above, or do you think I need to replace it?
Aces
07-01-2004 13:43:57
 Re: Re: Re: Question on steering problem on a 350. in reply to Jeff in IA, 07-01-2004 13:08:59
Jef you will need new or good used one and I don't think there is a good used one, the only way tou would find good used one if some one put one in for short time then junked tractor
Jeff in IA
07-01-2004 14:59:33
 Re: Re: Re: Re: Question on steering problem on a in reply to Aces, 07-01-2004 13:43:57
OK. Thanks again for the advice.
