350 steering
Hoppy
07-01-2004 10:00:11
I think I answered this some time back, on the 350 I'm currently working on the splines on the short shaft between the radiator and the sector was worn out. I drilled a hole through the shaft and coupler and put in a roll pin to solve the problem. Hope this helps as I feel this is the weak spot in the steering.
Jeff in IA
07-01-2004 13:03:45
 Re: 350 steering in reply to Hoppy, 07-01-2004 10:00:11
Thanks for the advice. It sounds like you're on the right track. Now my question is where would I put that pin in? Would one in front of the radiator be sufficient? Also, is one enough? Seems it may almost take a couple to withstand the strain.
