leaking out of the spark plug...help!
Sandy
07-01-2004 13:24:21
Hi...I have a great looking and running Super C, but noticed that there was some oil leaking out of one of the plug holes.
What could cause that...never seen it before.
Thanks in advance if you can help!
Chris
07-01-2004 20:05:04
 Re: leaking out of the spark plug...help! in reply to Sandy, 07-01-2004 13:24:21
This happen to H when I first bought it. When I rebulit the engine the rings were bad and was blowing oil by. If the eletrode on the plug is wet with oil you might want to run a compression check?
Hermit
07-01-2004 19:36:34
If a spark plug is not properly torqued or has a bad gasket or a piece of dirt is stuck on the gasket, there can be blow-by from the cylinder that looks like an oil seepage from the spark plug hole. Pull the plug and see if there is a gummy build-up on the threads. That is an indication of some blow-by leakage. If it's there, clean the threads, make sure the gasket and gasket face in the cylinder head are clean and torque the plug to the proper value.
El Toro
07-01-2004 15:30:50
Hi Sandy, Pull the sparkplug that has oil around it. See if it is wet with oil. If the electrode
area is dry the oil may be from a leaking valve cover. Is the tractor using more oil than usual?
If it isn't try snuging up the valve cover bolts,
do not over tighten them. Hal
