International 2444 w/ loader
Marty
07-01-2004 15:41:20
I've been shopping for a good used gas operated tractor with a front end loader. Didn't come across very many here in southern Missouri....except a 2444 International Industrial w/ 2050 loader and new rear tires. I called the guy...told me the starter sometimes sticks, it occassionally pops out of gear when there is no load on the engine/trans, and the governor sometimes opens up. He wants $4500. Is this a good price?
Ben in KY
07-02-2004 06:38:31
 Re: International 2444 w/ loader in reply to Marty, 07-01-2004 15:41:20
I have a 2444 with 2050 loader. I paid 4,000 about 1 1/2 years ago, mine was in good running order with no functional problems, just a bit of rust and a couple of leaks. Nice little tractors, however the one you are mentioning sounds like it has been rode hard and put up wet and might cost a fair bit to fix. I would pay about 2,500-3,000 max for that tractor if I wanted to fix it. Governor and transmission hard parts are not cheap for these models and can be difficult to find as they were only made for about 5-6 years and are a British based design. The 2444 is an industrial version of the 444. Gas or diesel ? The gas engine is not a sleved design and must be re-bored for a rebuild. I know someone that had his gas 2444 rebuilt, cost nearly 4,000!
Marty
07-02-2004 06:56:53
 Re: Re: International 2444 w/ loader in reply to Ben in KY, 07-02-2004 06:38:31
Thanks for your response. It is helpful. I'm not as up to date on tractors and making it important to gather as much info as I can in order to make a good purchase. I think you are right...I'll let this one go.
