smta tires
Don
07-02-2004 10:30:15
Is it ok to use 15-5 38 tires to replace 13-6 38 tires on the same rims on a SMTA?
Thanks
Don
BIG JOHN
07-02-2004 18:25:55
 Re: smta tires in reply to Don, 07-02-2004 10:30:15
Replaced 14.9 x 38's with 16.9 38 radials. Tires were used but just like new and price was really right. The tractor looks really good but it is just used for show. Has 700 x 16's up front.
Lance Ropte
07-02-2004 14:45:32
We tried that once on a 560 and plowed for only half a day and the tire looked like a mouse had chewed it up. The next day the dealer put 14" rims on it with a new set of 15-38 tires and the problem was solved.
TP from Central PA
07-02-2004 12:25:47
I'd put 15.5 x 38's on 15" wide rims if I were doing it..... .....Got Firestone F+R 15.5's on 15" wide rims on our 400 and they pull like mad with every ounce of rubber on the ground.
scotc
07-05-2004 19:09:59
 Re: Re: smta tires in reply to TP from Central PA, 07-02-2004 12:25:47
put 15.5-38 'stones on the sm's 14.9-38 rims, tires are rounded some but if there's any tire slip or soft dirt it's using the whole tread anyhow.
sammy the RED
07-02-2004 10:57:59
14.9x38's would look real nice on that Super M-TA.
rustyfarmall
07-02-2004 10:52:25
I have seen it done that way but it is not right. You really need a 14 inch wide rim to mount a 15.5-38.
captaink
07-02-2004 10:51:15
The 15.5-38” inch tire is made to be put on a 14” wide rim. If it is put on a narrower rim (which you probably have) it will be too “round” and will not afford maximum traction. If you are planning on using the tractor a lot, I would recommend either going back to the 13.6-38” tires or finding a set of 14” rims to mount the 15.5-38" tires possibly from a 460 or 560.
Wardner
07-02-2004 13:09:43
 Re: Re: smta tires in reply to captaink, 07-02-2004 10:51:15
I have a set of 15.5 radials on a SMTA. I bought new rims but had to weld new slipage prevention blocks on them. They could be rivited as were the original blocks on your existing rims.
Wardner
07-02-2004 13:12:03
 Re: Re: Re: smta tires in reply to Wardner, 07-02-2004 13:09:43
Forgot to mention that the new rims are 14 x 38.
