Tire Pressure
Gac
07-02-2004 14:10:15
I have a H that had tubes put in the tires. Stock size, what pressure do you run
little john
07-02-2004 14:25:10
 Re: Tire Pressure in reply to Gac, 07-02-2004 14:10:15
Hello Gac. I put 12 lbs. in my H's tires (I assume you refer to the rear tires).
Have a happy and safe fourth!
Mark
07-02-2004 14:25:08
If your not carrying a large drawbar load around 10lb and if you are around 15.
Mag Man
07-02-2004 16:46:32
 Re: Re: Tire Pressure in reply to Mark, 07-02-2004 14:25:08
I go with 12 To 14 Lbs JON
