H-4 mag ?
tiny
07-02-2004 14:29:53
Could someone tell me how the wires and fiber-washers go on the condenser? I pulled it a part and did not notice how they went.
Bob
07-02-2004 18:22:03
 Re: H-4 mag ? in reply to tiny, 07-02-2004 14:29:53
Here's the official version, from the Cub Collectors web site.
Mag Man
07-02-2004 16:40:33
I am not sure what your trying to say but I will try this. You have two fiber washers that go in the side of the mag on the inside Your condenser goes in the holes in the end of the two wires one for coil and one for points . The fiber washer on the inside protects the wires from touching the side of the mag . And the fiber washer on the outside protects the ground screw and wire from touching the side of the mag. HOPE THIS MAKES SENCE JON
tiny
07-02-2004 17:41:18
 Re: Re: H-4 mag ? in reply to Mag Man, 07-02-2004 16:40:33
How does it go to gether wires first or washers on the condenser? then thru the mag housing then the where the ground screw gose?
Mag Man
07-02-2004 18:33:40
 Re: Re: Re: H-4 mag ? in reply to tiny, 07-02-2004 17:41:18
Should be condenser, wire, wire,fiber washer,on the inside. Then fiber washer,Brass nut that screws to condenser on the outside followed by the screw that holds your wire for your on off switch. JON
tiny
07-02-2004 18:43:31
 Re: Re: Re: Re: H-4 mag ? in reply to Mag Man, 07-02-2004 18:33:40
Thanks Mag Man and Bob thats a lot of help
