how to find value of F12
Mary
07-03-2004 16:50:01
How do I find out the value for a F12, serial #2990DB? It is on steel, with pto, rock shaft & belt pulley, it runs. What else should I find out to list it? Thanks
Dan in Ore
07-04-2004 04:58:24
 Re: how to find value of F12 in reply to Mary, 07-03-2004 16:50:01
That number is not the serial number. That sounds like the casting number on the engine block.
The serial number would be located on a plate under the fuel tank right next to the oil pressure gauge.
If that is missing then look on a flat spot next to the fuel pump.
Hope this helps.
Dan
nebraska cowman
07-03-2004 16:53:47
I would think $1500 at least. Maybe a little more depending on location. I might even be interested myself.
