Timing a M Farmall
Bartley
07-03-2004 21:38:27
HELP!! How do I check the timing on an M? My M has a bad miss and back fires. Just put a new coil (12v system)on it. The points are set at .013.
Any feedback would be helpful.
Thanks
Bartley
TomH
07-04-2004 06:03:05
 Re: Timing a M Farmall in reply to Bartley, 07-03-2004 21:38:27
Points should be .013 if you have a magneto, .020 if you have a coil. Also make sure you son't have two of the spark plug wire mixed up, that will cause it to backfire.
TDK
07-03-2004 22:53:40
Try setting the points at .020 and try it.
Dick Davis
07-04-2004 02:58:32
 Re: Re: Timing a M Farmall in reply to TDK, 07-03-2004 22:53:40
Any chance the timing is 180 degrees off? Has the distributor been off or could anything have changed the gearing to the dist? Pull the rotor cap off and watch the rotor while someone turns the motor over. TDC on the crankshaft mark and rotor movement should tell you if you're 180 out. Good luck Dick Davis
Bob in Iowa
07-04-2004 05:38:18
 Re: Re: Re: Timing a M Farmall in reply to Dick Davis, 07-04-2004 02:58:32
Dick,
What is that big lot of semi tractors along I 80 just north of the Glenwood exit? Can't believe the number of semi tractors there. I am moving from Nebraska City to Sac City Iowa and get to see that part of the country much as I haul all my tractors.
Bob Frey
Dick Davis
07-06-2004 04:08:21
 Re: Re: Re: Re: Timing a M Farmall in reply to Bob in Iowa, 07-04-2004 05:38:18
Bob, the answer is rather complex but those tractors are older ones that came off leases when the federal pollution standards got tougher. Basically operators wanted the last tractor manufactured under the old rules, so tractors just older than that were turned back in. Many of those being "reconditioned" on site are very low mileage units. One report is that they have about 3000 pullers there. So Bob what will your handle be when you reach Sac City? I remember when you were Bob in SW Iowa. Thanks again for the parts especially the aluminum caps for hydraulics. Dick
