Diagnosing stuck distributor advance on '47 H
Dave in CT
07-04-2004 09:52:28
I pulled off the distributor on my H because a timing light didn't show any advance happening at the higher RPMs.
I've got the distributor disassembled - down to the plate on the distrubutor shaft that supports the weights and the weights themselves. The springs and weights look relatively new - rust is definately not the problem. When I move the weights out to engage the cam, they only move about 1/8" and the distributor shaft, after the cam engages, only rotates about 2 or 3 degrees. It looks like the weights should be able to move out all the way to the wall of the distributor housing and that would give the shaft the full advance rotation.
I just took off one of the weights and didn't find any 'Weight arm spacer's shown in I&T's exploded view. There are tiny washers on top of the weight - between the weight and where the spring hooks on. Are these the spacers and should they be on the other side - between the plate and the weight?
It just feels like something is catching and not letting the weights spin out to the fully advanced position. I'm trying to get to be able to do that manually before I put it back together. TIA
Answer for Bob - Dave in
07-04-2004 19:35:25
 Re: Diagnosing stuck distributor advance on '47 H in reply to Dave in CT, 07-04-2004 09:52:28
Thanks for the reply. I'm answering here because that image takes a while to load. I believe it's an IH distributor. So far my assembly is the same as your exploded view - with the exception of the washers or 'weight arm spacer's mentioned above. That exploded view is the same as my I&T exploded view. The numbers on the distributor are:
One side of body: 52
Other side of body: 353898R1
Side of flange where the distributor clamps clamp: HC5-757925
I'm used to a distributor where the plate revolves to advance with the greater RPM. I'm not getting the advance at the higher RPM (shown via the strobe timing light) but I'm not seeing how the weights are supposed to cause this advance.
riverbend
07-04-2004 19:59:08
 Re: Re: Diagnosing stuck distributor advance on '4 in reply to Answer for Bob - Dave in , 07-04-2004 19:35:25
If you unhook the springs, does the points cam turn to give enough advance? Do the weights move
out freely ? Is the lever on the weights hanging
up on the cam instead of turning it ? If everything looks okay, it could be that the springs are too
heavy.
Bob
07-04-2004 12:43:51
third party image
Is this view (from the TC-26E A and B parts catalog, on the Cub Collector's Site) similar to yours, or do you have an aftermarket distributor?
