560 wheel weights,different.
Chris Brown
07-04-2004 16:29:30
I just got the new 560 home and want to know how much the rear weights weigh. These are completly different than normal weights like that are on 560's and H's nd M's,this tractor has power adjust rims and it has a 3 or 4 inch thick weight inside and a 3 inch or so outside. The outside weight has F 560 cast into it.
scotc
07-05-2004 18:56:04
 Re: 560 wheel weights,different. in reply to Chris Brown, 07-04-2004 16:29:30
I bought a set of cast weights off a 86 series that had about 11" hole in the middle(just enough to go over 9-bolt hubs) that are about 4 times as think as regular weights, they weigh 900 each roughly. On one side the outer edge is rounded and the other is dished slightly.
