Re: Unknown eng post under help identify
Jim Becker
07-04-2004 19:44:54
Looks like a U-2 power unit. Probably came off of a combine or some such. It is basicly a Farmall Super A engine. The power unit blocks were not the same as the tractor blocks so the part number won't match the tractor book. With a 3 inch bore, it was 113 ci. If you plan to replace sleeves, you need to know the size of the lower bore in the block as later engines used a sleeve with a larger lower diameter.
