Farmall B need info {lots}
fred {mud} hu
07-05-2004 06:32:49
I just inherrited a model B and it needs alot of attention.I have an owners manual for it but will need a service and lots of advice on it.I got it tu runin well enough just a carb and or governor glitch, a noise in trany when in 3 rd gear, and some gaskets or seals in the rear end. Any help or advice woud be very much appreciated!
Thankyou for your time and troubles,located in mid-western Michigan Fred {mud} hudson
Tom of Hastings
07-06-2004 19:27:36
 Re: Farmall B need info {lots} in reply to fred {mud} hudson, 07-05-2004 06:32:49
Mud,
I've owned a B since 1972. I just had the engine rebuilt. Maybe I can answer some questions. E-mail me at docwrite@infionline.net.
Tom of Hastings
Bob
07-05-2004 09:29:05
These tractors didn't have the quietest tranny to begin with, but if yours is really bad, it could be a gear with a bad tooth, or two, or a bad bearing.
Gaskets and parts are mostly still readily available through your nearest CNH dealer.
jason
07-08-2004 10:01:32
 Re: Re: Farmall B need info {lots} in reply to Bob, 07-05-2004 09:29:05
I have a '42 B, and its gear noise will drive you near insanity. I was told it was due to straight-cut gears?????
