1950's Super C running poorly
jmcl
07-05-2004 16:48:40
Recently my father, brother and I have had a problem with our old Super C farm tractor. We mainly use it for cultivating purposes and it was a great tractor until this summer when it started acting up. It will start but it runs rough and puts out a bunch of black smoke....try to run it up much past half throttle it cuts out and dies. We've tried pretty much everything we can think of; changing plugs; soaked and completely cleaned the carburetor; new condensor; new coil; new external resistor. Points are fine and timing is good. Anything you fellas might be able to suggest would be much appreciated.
james williams
07-06-2004 15:47:58
 Re: 1950's Super C running poorly in reply to jmcl, 07-05-2004 16:48:40
Even though you cleaned the carb.was there any gas inside the float.Sounds like the float is heavy and carb. is getting to much gas
Ken in Iowa
07-05-2004 20:04:16
If you get black smoke it sounds like too much fuel and not enough air.
Try disconnecting the air filter hose at the carb.
If it runs OK with the hose off, your air cleaner is probably clogged. Good Luck, Ken in Iowa
