Whats wrong with my 560 steering?
Wayne
07-06-2004 06:08:55
My wide front Farmall 560 road wonders terrible. The toe in is set proper (about 3/4 of an inch), the tie rods are tight, and steering knuckles are tight. The tractor has the short turn kit on it. How big a job is it to get into the steering box? The tractor is low hours so how could the gears be worn that much? Something has got to be wrong in that box. Nobody seems to know anything about it. Help----- Thanks.
Aces
07-06-2004 13:47:31
 Re: Whats wrong with my 560 steering? in reply to Wayne, 07-06-2004 06:08:55
Wayne If it steers easily, it could be the ball screw in side the bolster housing or the rack could need adjusting up to the bolster shaft the sleve the rack is in can be turned to adjust the rack and bolster if the rings on the rack are bad the oil could just be going by but I would thing it would steer hard. To get at this you need to remove the left side rail and the radiator. Make sure put stand under TA housing before you remove the rail.
