Order Farmall Cub Parts Online
Fixing the loose steering on a Cub tractor
a bane
07-06-2004 19:30:16
What is the best and cheapest way to fix loose steering on a Cub tractor.The steering has so much play that it's very hard to hold in the row.
Ed
07-06-2004 19:46:44
 Re: Fixing the loose steering on a Cub tractor in reply to a bane, 07-06-2004 19:30:16
if its not the tie rod ends, you can turn the gear in the steering to run on teeth that have'nt been used yet, you may also have to pick up a different worm gear (its part of the steering shaft)
