560D hydralics won't lift
Don
07-06-2004 19:54:18
I have a 560 diesel with 2pt to 3pt adapters that I put a Kuhn 8' dics mower on. When I tried to lift the cutter bar it pulled the remote cylinder tight enough to twist the frame, but would lift the bar off the ground.When I tried the 2pt it would lift the entire unit off the ground. I checked the hydralic level and it was full. Can the pump be adjusted or is it going bad? Any other suggestions?
Chris
07-09-2004 16:33:23
 Re: 560D hydralics won't lift in reply to Don, 07-06-2004 19:54:18
Hello Don. No It will not lift the cutter bar, I have a 8 ft cutter and it will not curl my cutter bar neither, It has 1350 psi on the gauge,so I am cutting with a 5000 ford that has 2500 psi on the gauge, and it has no problems curling it,If anyone know's how to fix this,PLEASE LET US KNOW,SORRY CHRIS
Joe Evans
07-07-2004 10:22:34
I don't understand you post. It sounds like your hydraulics ARE lifting, but your topic is "...won't lift".
