C50 transmission
cowmansam
07-07-2004 05:22:27
I don't know if this is too new for this forum or not and if it is than I'm sorry. My problem is sometimes I can't get this tractor in any gear at all. Sometimes it will work fine. Going to high range or to 4th seems to be the worst. Is there something to adjust or shim up or bend or something to give me some relief? The tractor only has 470 hrs, does it need to be used more? thanks
Novel Idea Guy
07-07-2004 05:48:44
 Re: C50 transmission in reply to cowmansam, 07-07-2004 05:22:27
Yes, it's too new. I believe the cutoff point is officially 1975 for this forum, though it seems the moderators rule with cotton-candy fists. Those new tractors are far too complicated for most of us "barnyard mechanics." :)
Isn't your C50 still under warranty? They haven't been out that long. You should complain to your Case-IH dealer, or to Case-IH directly. I wouldn't settle for a NEW tractor that doesn't shift.
