300 U Value
Mark / ct.
07-07-2004 15:45:09
could anyone out there give me a best guess as to
the value of a 55 ih 300u, good tin & emblems,engine runs good,smooth, no skip, no smoke, no knocks, trans. quiet,stays in gear, fast hitch, loader,(hyd. bucket with down press). no TA. no pwr. steering, good rear tires 95%, fronts 10% needs gauges tach.stopped at 42xx hrs.charging sys.works NE.location, also what are the good and bad points of this tractor/setup? thanks Mark
TDK
07-07-2004 20:01:14
 Re: 300 U Value in reply to Mark / ct., 07-07-2004 15:45:09
Here in the southeast,a 300U in condition you describe, probably 2000 - 2500 dollars. Add for loader - if it's an older pipe-type,add $300 - 400. If it's a 60's - mid 70's model add $1000 - 1600. Check the play in steering box. Excessive play can usually be adjusted out if no one has previously adjusted it before. You'd be surprised at these that no one ever bothers to adjust. Tough tractors,easy to work on.
