tired f-12
shank
07-07-2004 16:48:50
1938 f-12 starts up & runs good for about an hour and then it starts popping and finaly dies.Rebult mag,new plugs & wires & rebuilt fuel pump.Could it be the valves?Thanks in advance for any help,Shank.
nebraska cowman
07-07-2004 17:09:18
 Re: tired f-12 in reply to shank, 07-07-2004 16:48:50
sounds like a weak coil. Check your spark cold, then again warm. It should throw a blue spark a quarter inch. yellow fire won't cut it.
Shank
07-08-2004 10:26:05
 Re: Re: tired f-12 in reply to nebraska cowman, 07-07-2004 17:09:18
It acted the same way befor I had the mag rebuilt.The mag has everything new inside.I will check the spark when it`s hot.Thank`s,Shank.
Bobcat
07-07-2004 19:55:56
I would unscrew the gas cap. Do you hear anything?
