M with a virus
martin sterlets
07-08-2004 04:38:11
i,ve restored a model M. Runs great on on all RPMS while working or standing still. BUT, some times , for no reason it will backfire and shoot flames for no reason that i can find and than returns back to running nice. this accures weather its hot or cold and can last one to 15 minites at a time. it may run great for days at a time. could use HELP...
Bus Driver
07-08-2004 17:23:00
 Re: M with a virus in reply to martin sterletske, 07-08-2004 04:38:11
I agree with pete's suggestion about the distributor cap. Could be arcing between plug wire towers (inside or out) or two plug wires could be arcing together.
Pete
07-08-2004 15:21:09
Is the backfire comming from the intake or the
exaust? If it is backfiring through the intake
it could be from a lean fuel air mixture. Backfire through the exhaust indicates some
type of timing problem posibly a sticking valve
or maybe arcing in the distributor cap.
captaink
07-08-2004 07:16:04
Maybe try running some gasoline with 10% ethanol through that M. The ethanol will absorb the water and get it out of the tank, carburetor etc.
*disclaimer—this is only if your fuel system is CLEAN. Ethanol is a wonderful cleaning agent and will not only get the water out but other crap in the tank too!
Justin-PA
07-08-2004 06:26:58
Just another thought...could be an exhaust valve sticking open. Maybe there is heavy carbon build-up or the valve is slightly bent and sometimes sticks open. If a batch of new gas doesn't help, I would pull the valve cover and check out the valve operation.
Just a thought.
martin sterletske
07-08-2004 14:10:54
 Re: Re: M with a virus in reply to Justin-PA, 07-08-2004 06:26:58
interesting thought, had a valve job done, but would'nt it be a consistent problem. [only sticks when hot or cold] ??? good thought....
Mag Man
07-08-2004 04:41:25
I would say maybe water in fuel. JON
martin sterletske
07-08-2004 05:06:24
 Re: Re: M with a virus in reply to Mag Man, 07-08-2004 04:41:25
I've concidered that, there has been noticeable condensation on top of the float bowl, changed gas, added heet and still no changes, thanks mag man
Novel Idea Guy
07-08-2004 06:06:00
 Re: Re: Re: M with a virus in reply to martin sterletske, 07-08-2004 05:06:24
Where are you getting your gas from? If the new gas came from the same tainted supply as the old, then its no wonder there was no change.
martin sterletske
07-08-2004 14:03:48
 Re: Re: Re: Re: M with a virus in reply to Novel Idea Guy, 07-08-2004 06:06:00
different gas, different octane used. how about a cracked intake\exhaust manifold...
