arcing between coil wires
Dennis
07-08-2004 08:02:49
I noticed intermitten sparking between the two wires coming off the coil of my 300U yesterday.
What do I check? Bad wires or bad coil?
Thanks for any help. I am pretty stupid when it comes to electronics.
captaink
07-08-2004 09:21:53
 Re: arcing between coil wires in reply to Dennis, 07-08-2004 08:02:49
Arcing at the coil usually is caused by bad electrical connectivity somewhere between the high tension coil terminal (the wire that goes from the coil to the distributor) and the spark plugs. Check (or replace) the distributor cap and rotor for corrosion. Check the cap on the inside of the spark plug wire terminals on the outside of the cap and on the inside of the cap for corrosion on the terminals. Check the rotor for corrosion. Next would be to install new spark plug and coil to distributor wires. Lastly, put in new spark plugs.
Good Luck!
Ben in KY
07-08-2004 11:35:37
 Re: Re: arcing between coil wires in reply to captaink, 07-08-2004 09:21:53
Also clean the top of the coil. Buildup can cause arcing there. There might already be a carbon path or crack there causing the arcing. If so you will have to replace the coil.
