Order Farmall Cub Parts Online
Cracked Cub Head
Gene
07-08-2004 08:37:06
Just purchased a Cub. Has a cracked head in the water jacket on top surface of the head between # 2 and 3 cylinder. Cub runs fine. No evidence of a crack on the combustion side of the head.
My thought, without removing the head from the block, is to grind a shallow "V" along the crack, heat (warm up) the head along the crack with a propane torch, then apply JB Weld to the crack. I have tried this before on other castings but never a head.
If this doesn't work, I'll spring for another head.
Your opinions.
lee
07-08-2004 09:28:22
 Re: Cracked Cub Head in reply to Gene, 07-08-2004 08:37:06
I had a cub with a crack on top. Somebody had plastered over top rather sloppily but it never leaked the 6 tears I owned it.
Not a real fan of JBweld but it'd probably work.
I'd probably look for a better product.
Here are some possibilities, although I've not tried them, they look pretty good.
Link
Link
Link
http://www.c-mesales.com/index.html?target=p_60.html&lang=en-us
