IH Farmall Help Please
debbie
07-08-2004 18:59:00
I have an old IH Farmall that I have owned for 30+ years and it was old when I got it. I am in need of a new belly mower as hers is just about had all the welding it can take. I have no idea what model it is and have no idea where to look for that information. I think it was built in the 1950s. Can anyone tell me where to find the serial number or model number. Also any idea where I can get a belly mower and how much I should pay for it. My thanks in advance
Christopher S. Dunn
07-09-2004 05:33:01
 Re: IH Farmall Help Please in reply to debbie, 07-08-2004 18:59:00
Debbie, the serial number should normally be under the seat on a small metal plate against the side of the tractor. At least on most models. Also, if the front has wide stance wheels then it is probably an A model and if it has the tricycle stance, then it is most likely a B model.
The gallery here would be helpful under the tractor photos section and if you have a picture that you can post, I am sure someone can answer you as to what model tractor you have.
Good luck to you.
sammy the RED
07-08-2004 21:46:51
When you would buy a oil fiter for it, what did you ask the parts man for ?
BILL
07-08-2004 21:02:36
woods will sell a mower to fit most any farmall or IH tractor, I just bought one for a 154 cub low boy. 60 in. cut cost $1500.00
Bill
nebraska cowman
07-08-2004 19:32:32
my advice would be to look through some of the galery pictures and find one like it.
debbie
07-10-2004 01:53:11
 Re: Re: IH Farmall Help Please in reply to nebraska cowman, 07-08-2004 19:32:32
I will be off work Mon so will go and check for that serial number. It is the type with the wide spaced wheels. I want to thank all of you for your responses. I had already checked out the pictures and did not see one just like mine but maybe someone had sone some modification on mine..Again thanks
