What causes backfire ?
waynekittler
07-08-2004 20:21:14
I put new points in and adjusted the tappets on the 574 gas on Memorial Day. Now it backfires sometimes on either start or shutdown? Why ?
Gene
07-08-2004 22:12:55
 Re: What causes backfire ? in reply to waynekittler, 07-08-2004 20:21:14
Timing is off. After installing new points you need to time the engine. Get out the timing light and adjust the distributor - retime the engine. My guess is that the point gap is not set correctly.
Double check the tappets. One or more could be set to close/tight.
Cause of back fire - Anything involved with the engine timing. This includes the ignition system and the valve train.
captaink
07-09-2004 06:48:14
 Re: Re: What causes backfire ? in reply to Gene, 07-08-2004 22:12:55
Righto… I agree point gap is probably off. Probably too wide, retarding the spark enough that the combustion is not complete before the exhaust valve opens causing the backfire.
I would also check a shop manual (like an IT manual) or owner’s manual to see if the valve adjustment is to be done HOT or COLD. As the engine warms up, the valve train parts all expand slightly, which will absorb some if not all the tappet gap. If the valve clearance is to be set HOT and is set COLD instead, not enough clearance will remain in the valve train when the engine is warm causing valves not to close properly. This will also cause backfiring.
