Farmall B valves
John *.?-!.* cu
07-09-2004 07:41:06
The service manual for Farmall B and A say not to replace the valve seats with inserts. Does anyone know the reason?
Thanks
captaink
07-09-2004 08:27:26
 Re: Farmall B valves in reply to John *.?-!.* cub owner, 07-09-2004 07:41:06
I’m not sure if the A and B had the valve seats just cast into the head or if there were replaceable seats from the factory. I’m guessing that they were just cast into the head, so and installing replaceable seats would be something beyond what a normal mechanic could do. Thus the shop manual not including it. Any reputable machine shop should be able to cut in seats, and Lee makes a good point about having the newer harder seats installed so that you don’t have any issues when you run the "modern" unleaded fuel.
lee
07-09-2004 08:33:33
 Re: Re: Farmall B valves in reply to captaink, 07-09-2004 08:27:26
The seats I had installed were cut in at an automotive machine shop..
lee
07-09-2004 08:12:16
never heard of that. I had 8 stellite inserts installed because the valves were sunk too deep in the head. works great, no issues with unleaded fuel, not cheap.
