aftermarket powersteering on Farmall H?
Schmidty
07-09-2004 19:37:49
Years ago I helped an old farmer put some hay up in his barn. The H he used to move the wagons had a rather unique power steering set up which consisted of a hydraulic motor mounted to to the steering column between the throttle and the gage set (the column actually ran thru the hydraulic motor), some hydraulic hoses and some sort of a brace. I wonder to this day if it was something he fabricated or if it was a short-lived aftermarket experiment. I have yet to see anything like it.
Schmidty
26Red
07-12-2004 08:14:32
 Re: aftermarket powersteering on Farmall H? in reply to Schmidty, 07-09-2004 19:37:49
Sounds like a Belhen unit. They were used on the 350 and 450 series tractors with the whole unit mounted under the hood. Charlynn offered a cleaner setup, the powersteering motor mounted under the hood infront of the temp and oil gages.
check out Force America. They still sell kits for the M.
Schmidty
07-10-2004 14:01:21
Thanks Bob and Will! That clears up an old mystery for me. I should stop by that farmer and see if he has it yet. How much would that set up cost? I have an H I would like to add PS to.
Schmidty
Bob
07-09-2004 23:17:01
In addition to Behlen, there were Char-Lynn units, which are still available.
Link
Will Sick
07-09-2004 22:30:01
Sounds like a Belen unit. A lot of them were sold and put on M's more than H's. They had them for other tractors too. The pump was between the distributor and timing gears.There was also a tank for oil.
