Farmall B how do I find year it was made
fred {mud} hu
07-10-2004 03:11:37
I want to know what year the B is that I inherrited from my sister. Where do i look for #'s on it , and who could tell me once I find them ? As of yet I have not found anyone close to me that has alot of patiance and knowledge, to help me along with the repairs.I live in Newaygo ,Michigan 1/2 hour north of Grand Rapids Thankyou for any help and advice !!! Fred { MUD } Hudson
Craig R
07-29-2004 04:58:03
 Re: Farmall B how do I find year it was made in reply to fred {mud} hudson, 07-10-2004 03:11:37
My father has a farmall B with the following numbers:
1.) 8638 DE was located on drive shaft housing
2.) 6342-DA was located on the engine block.
Can anyone tell me if these numbers translate to the year the tractor was produced?
Dave BN
07-11-2004 05:57:43
Fred, I live in Ravenna Mi. I have a BN and a good general knowledge of it. Let me know if I can be of help. Serial number should be on left seat post and by #1 plig on engine block. Dave.
rustyfarmall
07-10-2004 07:16:33
You can look for casting codes, located on the axle housings, torque tube, engine block, etc. The codes will look like 6*15*I, which would indicate a casting date of June,15, 1939. The letter I is for 39, J is for 1940, K-41 etc. Not all letters are used so it does get confusing at times but if you can find these codes on the tractor, let us know what they are and someone will be able give you a clue as to what you have.
farmerjohn
07-10-2004 19:06:51
 Re: Re: Farmall B how do I find year it was made in reply to rustyfarmall, 07-10-2004 07:16:33
I would like to know what letters were not used, no wonder I get it wrong sometimes.
Joe in Nova Scotia
07-10-2004 10:10:26
I have a W4 McCormick-Deerring with searial # BHM12399 on the block and #WBH12648 on the trans. housing. Could someone out there tell me if it is a 45 or 46. Also would the parts of a farmall H fit my W4. Thanks for the info.
little john
07-10-2004 03:28:50
If you find that serial number, you can go to the left of the page under Research & Info and match the year with the number.
JFKY
07-10-2004 03:19:16
look for a plate under the seat on the inside of the bracket. There (if it has not been removed) you will find the serial number that you can match with the year produced. They in general were made 1939-1947 I believe.
