Cmore recycling hydraulic oil..how to fix
Cmore
07-10-2004 17:17:03
Cmore's fast hitch wouldn't raise so filled up with 20w non-detergent. Then discovered this afternoon that Cmore was low on hydraulic oil again...because it's going into crankcase!! Drained probably quart to quart and one half off out of top petcock on pan. How hard to fix? Do I remove the hydraulic pump and install new gasket?? Is this difficult?? Thanks for any and all advice..Cmore
CNKS
07-10-2004 18:00:40
 Re: Cmore recycling hydraulic oil..how to fix in reply to Cmore, 07-10-2004 17:17:03
You have to remove the pump. It will have on the shaft either an regular seal or an o-ring. If the shaft is badly grooved you will need a speedy sleeve to put over the shaft. This is no problem if it is a seal. If it is an o-ring, you will have to have the hole the shaft goes through enlarged to allow room for the speedy sleeve. Good idea to replace the gasket where between the pump and the block, and two o-rings that fit between the oil tubes (from the resevoir) and the pump. There is also a seal between the two halves of the pump that should be replaced. There is more than one pump, you might want to take yours to your Case-IH dealer to be sure you get the right parts, unless you want to try just the o-ring or seal first and see if it works.
CNKS
07-10-2004 18:02:35
 Re: Re: Cmore recycling hydraulic oil..how to fix in reply to CNKS, 07-10-2004 18:00:40
The correct oil is Hytran. If you use engine oil, the original touch control was designed for SAE 10.
dan
07-10-2004 17:58:46
my c has same problem niebor has super c and 200 that do the same thing he has replased seal in both tractors many times ih dealer has done as well now he does the same thing i do run same oil in touch control as engine drain uper pet cock into can dump back into touch control resivor twice a summer is about all i have to do it
