1206 hp
Joe
07-10-2004 18:32:43
I bought a 1206 a month ago. Today I put it on the dyno and it only had 100 hp so I turned up to the pump and easly got 140hp. Is this too much? Or should I turn it down alittle? It runs excellent and had good black smoke when it was being dynoed. Just wondering what all you guys think.
Joe
07-11-2004 11:18:14
 Re: 1206 hp in reply to Joe, 07-10-2004 18:32:43
Thanks alot from all you guys that replied. I think I will leave the pump set the way it is now and put a pyro on it. One more question if you guys dont mind. The left brake only works if I push real hard. I took it apart and had 2 real good used disk out of our 856 that I put in. The ones in the 1206 were shot. I put it all together and bleeded it and I still need to push real hard to make it work.What else could be causing this problem. I know I got it together right because I have fixed them on our 856 before plus I went by the shop manual.Thanks for any help. Also I have a good brake piston and seals on it.
the tractor vet
07-11-2004 10:53:27
It would be smart to install a PYROMETER on it and i would install the probe BEHIND the turbo in the exhust pipe about 2 to 3 inches and never let it get over 950 as that will be close to 1250 -1350 on the hot side . By installing the probe their if it MELTS OFF then it goes out the pipe not thru the charger.
JimB
07-10-2004 21:04:11
Ran 1206 for years at 165hp. No problems.Just use your head.
1206SWMO
07-10-2004 21:02:39
I farm with (2)1206's that have never been on the dyno since I bought them.Both must be in the 130-140 hp range as they will pull a 21 ft disk,14 ft trail chisel,and 24 ft field cultivator in high 1st with TA forward.They are as stout as my 1456.
Just dont over weight or over load a turned up 1206 and you will be OK.
Larry B.
07-10-2004 20:23:44
Factory came out at 112 hp. I run mine at 115 hp. At 140 could cause some problems.
